How to stop wheel hop questions
FastCraig
407
594
Huntington, WV
Look at "G-BODY SHUFFLE".
20,391
If you want the answer to your question the only way to stop wheel hop questions if everyone agrees not to ask........:popcorn:
81cutlass
4,649
13,565
Western MN
I dealt with this last year.
New shocks-still hopped
Adjustable uppers (helped center the rear in the car and dial pinion angle in, heims on car side poly on axle side)- still hopped
Boxed lower stock arms-still hopped
Put in poly lower control arm bushings-fixed it
Not saying poly lower bushings are the end all solution, as stated I'd check shocks and the bolts being tight first, but bushings seemed to fix it for me.
79 USA 1
1,065
2,039
Cheektowaga, New York
Finally got my internet service back.
fleming442 has it right. loosen your control arms where you had removed them. retighten them with the weight of the car.
The 79 manual calls for 70-75 pound foot for the torque value.
I had gone through a similar problem with my now parts car (79 Monte Carlo) after pulling the rear housing out for a gear swap and boxing the lower control arms.
Re installed the rear axle and had bad wheel hop.
I put a set of no hop bars in ...still hopped.
Went back loosened and re-torqued all the control arm mounting points with the weight of the car on the wheels.....Problem solved.
9,170
15,360
Another thing to look into if it wasn't brought up, what condition are the bushing in? New one, rubber, poly, or other options might help but I'd list that at the bottom of the list that would fix it thou.
dickeymoore
924
Atlanta,Georgia
I did like 79 USA 1 said and it worked now I am printing the tires from a standstill through first and second gear with a vacuum secondary Holley carburetor thanks everyone for the information and advice!!!!!!
Doug213xrj
1,529
131
West Michigan
Replace the rear control arm bushings. I went with polyurethane bushings from Energy Suspension. No more wheel hop.
Doug
