I know that the steering shaft has been covered here....100 times.
I've never seen the cherokee steering box talked about on a forum though.
I've mentioned it a few years ago. In fact, Hot Rod Magazine did the article back then.I know that the steering shaft has been covered here....100 times.
From my understanding, the gearbox is a direct bolt on in terms of pattern onto the frame correct? Is the pitman arm the same, or does it need to be swapped? The fittings are the same as the late G's with o ring style.Yep, did this upgrade a few years ago, amazing as my car was an F41 car, and this was much tighter and more responsive.
12.7:1?
To be clear.
The Jeep Snagawhore box is what ratio?
Also ... What is the ratio of a WS6 box?
