Have they removed everything since it broke at the track? If one of the ring gear's teeth came off and worked it's way around the carrier housing before being caught by the magnet you can have more issues than just a ring and pinion swap. IMO, if you want to get it just to sell the stuff on there then it's an alright deal. If you are wanting to put this in your car to race or something I'd say no. Especially with 4.56 gear and a spool.
Like said countless times before, bolt in housing (Ford 9", 12-bolt) or an 8.5"
The reason that the 7.5" gets such a bad rap is because they built so many of them that quantity rapidly outweights the quality. Some last forever and some last 5 minutes. It's all in the modifications. You can make a 7.5" last into the 10's if you use the right combination. You could probably do it with less than $350 in parts.
Real question is, what do you want to accomplish by getting a new rear end?
