It'll hold up to the power my motors making, and I can go with a bigger slick at the track and still not worry. I pressure washed it with superclean and there are no visible cracks in the housing, the ring and pinion are toast and the mini spool is gone. I bought a set of OEM 3.73's for it and an eaton posi that better fit my 350 olds and th350.The axles are in good shape as well, no splines are wiped off the axles and no cracks either. I plan to put a girdle on it and a new coat of paint to finish it off.
Here's how much I've spent so far.
-Complete rear with "no-hop" bars and brakes-$150
-OEM gear set/eaton posi-$250
-Master overhaul kit-$140
I'm just under $600 and I could keep it that way but i plan on getting a girdle for it but even with that it will still be cheaper than a stock 8.5 or 9 inch and is just about as strong as a stock 8.5 as well.
Since it is also the same housing thats in my cutlass already the brakes, rear suspension (sans upper control arms) and brake lines will be swapped over.
Here's some pics before it was torn apart.
