Put switch on high and tap the blower motor. If it comes on, a bad motorCorrect, the blower is not coming on. I’m getting nothing at all from any of the control settings, including the fan.
Thanks. I’ll give it a try.Put a test light on the blower motor wire, if it doesn't light bad switch or an interruption to power on that wire. If it does light up bad motor.
What about the ground??Put a test light on the blower motor wire, if it doesn't light bad switch or an interruption to power on that wire. If it does light up bad motor.
All you are checking is to see if you have power at the connector end. Probe on the wire, black clip to ground. If you don't have one, make one from an old side marker.What about the ground??
