Ugly1
Add a resonator, cheap but effective. Allows for sound “expansion/ dampening “ but still have tone
Saw that J pipe setup on a aftermarket exhaust for a buddy’s car. It said it was “adjustable” for drone noise but still keep going tone.Something I didn't see mentioned was a j-pipe. This is a misunderstood subject. Many factory mufflers, such as 2010 up camaro, have an internal j-pipe. A j-pipe is just a capped off section of pipe that allows sound waves (not airflow) to go in , bounce back, and cancel out. ABSOLUTELY NO performance lost. Some systems, such as aftermarket ones made for LS powered GTO's used a j-pipe with no mufflers to be full out loud with no drone. Nothing new here, just not common knowledge.
Home and commercial water pipe systems have a dead ended cap off somewhere to dampen and eliminate pipe banging noise.Similar thing.
There are these formulas to calculate the heinzholm frequency to determine best length of j-pipe application, but I get lost with all that crap. Some premade setups have a sliding adjustment to change the range that you get the canceling effect.
As far as mufflers ,corsa is one of the brands using noise cancelling chambers, which commonly remove a section of sound and get rid of drone. They are making universal mufflers now, but last I checked a little hard to find and worst of all for us, their sh#t ain't cheep. Bout 300 bucks for a muffler last I checked.
That's my free time limit at the moment, google search time.What you don't know may help.
I was reading about those and it seemed great, other than my packaging requirements meaning it's probably a no-go. Some of the Flowmaster stuff is using a similar concept. Unfortunately, all of them are just huuuuuuge.Something I didn't see mentioned was a j-pipe. This is a misunderstood subject. Many factory mufflers, such as 2010 up camaro, have an internal j-pipe. A j-pipe is just a capped off section of pipe that allows sound waves (not airflow) to go in , bounce back, and cancel out. ABSOLUTELY NO performance lost. Some systems, such as aftermarket ones made for LS powered GTO's used a j-pipe with no mufflers to be full out loud with no drone. Nothing new here, just not common knowledge.
It's 2.5 OD. 1-5-3-6-2-4. It has a "long tube" header on it too, although I'd say it's more like a shorty in any other application. But it definitely is a low frequency drone.I was working on design today. Will weld up a couple different designs this week and send to you to try.
Just to verify you have 2.5 ID coming from over axle?
I need to look up actual firing order, yet so far the drone mathematically is somewhere between 46 to 54 Hz, so very low frequency.
Is the cam stock OEM?
