I need a small but quiet muffler
jlcustomz
983
1,096
Something I didn't see mentioned was a j-pipe. This is a misunderstood subject. Many factory mufflers, such as 2010 up camaro, have an internal j-pipe. A j-pipe is just a capped off section of pipe that allows sound waves (not airflow) to go in , bounce back, and cancel out. ABSOLUTELY NO performance lost. Some systems, such as aftermarket ones made for LS powered GTO's used a j-pipe with no mufflers to be full out loud with no drone. Nothing new here, just not common knowledge.
Home and commercial water pipe systems have a dead ended cap off somewhere to dampen and eliminate pipe banging noise.Similar thing.
There are these formulas to calculate the heinzholm frequency to determine best length of j-pipe application, but I get lost with all that crap. Some premade setups have a sliding adjustment to change the range that you get the canceling effect.
As far as mufflers ,corsa is one of the brands using noise cancelling chambers, which commonly remove a section of sound and get rid of drone. They are making universal mufflers now, but last I checked a little hard to find and worst of all for us, their sh#t ain't cheep. Bout 300 bucks for a muffler last I checked.
That's my free time limit at the moment, google search time.;) What you don't know may help.
Ugly1
1,628
1,351
Lost in the woods of NH
Saw that J pipe setup on a aftermarket exhaust for a buddy’s car. It said it was “adjustable” for drone noise but still keep going tone.
2drx4
116
168
The middle of BC, Canada
I was reading about those and it seemed great, other than my packaging requirements meaning it's probably a no-go. Some of the Flowmaster stuff is using a similar concept. Unfortunately, all of them are just huuuuuuge.
But... Amazon totally screwed my on the cat I ordered and hasn't shipped it. Classic honeypot, it was 20% cheaper than Summit, but it doesn't actually exist sooooo that's not a better deal. I ordered a resonator too, figuring I'd leave myself some options, it might show up today. Then I can see how it all might fit.
78Delta88
1,306
1,090
SW Arizona
I was working on design today. Will weld up a couple different designs this week and send to you to try.
Just to verify you have 2.5 ID coming from over axle?
I need to look up actual firing order, yet so far the drone mathematically is somewhere between 46 to 54 Hz, so very low frequency.
Is the cam stock OEM?
2drx4
116
168
It's 2.5 OD. 1-5-3-6-2-4. It has a "long tube" header on it too, although I'd say it's more like a shorty in any other application. But it definitely is a low frequency drone.
I really don't think you want to be sending me anything though... It's not going to be cheap.
I'm not going to have it driving again tomorrow, but Amazon did deliver the resonator I ordered. I will see if I can fit it, but what started as a link mount repair has turned into plating half the frame, new mounts, new links, bumpstop and shock adjustments, and probably a bunch of other stuff that will be knock-on effects from the other things being changed.
