Ignition switch rod
Bigtexs
Bigtexs
32
27
8
#1
So my electrical ignition switch went failed on my 81 El Camino today. I removed the old one with no issue but when I went to reinstall the new ignition switch the rod that moves when I turn the key fell out of position. I eventually pulled the rod out thinking I could reposition it but I couldn't. So my question is how the hell do I reinstall the rod without tearing the steering column apart?
Bigtexs
Bigtexs
32
27
8
#2
On the bottom picture I'm pointing to the rod that needs to be installed.
airboatgreg
airboatgreg
1,286
1,206
Ease the rod up there as it usually goes into place pretty easily. Turn the key back and forth while doing so may help. Patience grasshopper.
Bigtexs
Bigtexs
32
27
8
#4
No luck after 2 days of trying. I'm tired and ready to sale the whole damn vehicle. So it that the only way to install the rod?
airboatgreg
airboatgreg
1,286
1,206
Pretty much. I am telling you it is not that hard. You have the end where it goes into the switch up. No electrical part to the switch installed. The column straight with no tilt.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,126
9,319
Kitchener, Ontario
#6
It's not too difficult to remove the whole column if you want to work on it on the bench. You may have an easier time to get the rod in.
Bigtexs
Bigtexs
32
27
8
#7
Ok airboatgreg after a drink or two I'll give it another try. Thanks for the info guys.
airboatgreg
airboatgreg
1,286
1,206
And hence could be the issue. You shoulda started earlier
Similar threads
