I'm an idiot... Where do these plugs go?
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
I pulled the 4.1 v6 out of my Regal way too quick and didn't label anything... Thought I was smart, now I have some random connecters that I don't know where they go. I had my old Chevette memorized like the back of my hand and just figured I knew enough to figure it out... IMG_20200728_145909882.jpg IMG_20200728_145848311.jpg temp or oil pressure?
IMG_20200728_145918951.jpg IMG_20200728_145921952.jpg totally lost on this one with the resistor.
IMG_20200728_145942513.jpg positive to distributor/coil?
IMG_20200728_145947790.jpg Electric choke?
IMG_20200728_145955598.jpg negativ the dist/coil?
IMG_20200728_150009942.jpg IMG_20200728_150012747.jpg temp sensor maybe?
IMG_20200728_150031378.jpg IMG_20200728_150033525.jpg F**Ked if I can even guess at what connector this might be...
I feel extremely stupid here, I know better than to do this.. any help would be greatly appreciated. Want to get this sbc running.
melloelky
4,162
9,569
mass
first looks like the alt,the second one is the oil pressure,third is to the positive dist,the last two pics are for the hvac.
that green one(#6) might be a temp sensor that was in the head.
84cutspreme
1,146
152
I pulled the 4.1 v6 out of my Regal way too quick and didn't label anything... Thought I was smart, now I have some random connecters that I don't know where they go. I had my old Chevette memorized like the back of my hand and just figured I knew enough to figure it out... View attachment 153097 View attachment 153096 temp or oil pressure?
View attachment 153098 View attachment 153099 totally lost on this one with the resistor.
View attachment 153100 positive to distributor/coil?
View attachment 153101 Electric choke?
View attachment 153102 negativ the dist/coil?
View attachment 153103 View attachment 153104 temp sensor maybe?
View attachment 153105 View attachment 153106 F**Ked if I can even guess at what connector this might be...
1st one with resistor is compressor wire
next one round I think ac press switch on accumulator
distrubutor ones look correct
choke correct
single green is fan for heat/ac and should connect to connector that looks the same
last 4 prong connector ac stuff too
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
choke correct
Thanks for the quick response. The only thing is this is a factory heat only car. And I unplugged all of these from something when I removed the drivetrain. The distributor ones are what I need to most to get this to start. So I can get my motivation back lmao..
I was stupid to not label things as I took them apart. But I was excited and figured once I eliminated the ecm everything would get simple.
  • Optimistic
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
I think the big round one two prong one must be the oil pressure, what's throwing me off is it doesn't have the usual gm plastic buckle that locks around the sensor.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
My car has an idiot light for oil pressure and gauge for temperature. There's no plug that looks like it would plug in to a temperature sensor.
I don't even know what ports they use for temp and oil pressure on a Buick V6
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Even idiot lights need sending units. ;)
Right, so why don't any of the plugs look like they'll fit? Shouldn't the electric choke be tied in with the temperature somehow too?
Figured everything was going to be pretty obvious when I put it back together 😂 it's not like there's that many wires
