Installing alt on passenger side
Bri guy
845
225
Get their billet pulleys for a 6" water pump and be done. They have pulleys that aren't ridiculously under driven. That skinny pulley is for the air pump. You need two belts driven off the crank or it will squeal so bad it will actually burn off the belts. That is the normal vin Y setup, the A/C is driven off the other groove, you have that removed, so only one belt driven off the crank. Non A/C pulleys are different and use a shorter water pump.
Maybe i will have to see what kind of options they offer for the pulleys. Seems lile i keep buying stuff and then it needs modified to work! You guys know how my car is when i work on it! Its been windy here too. It rained, snow and hail all in 10 minutes yesterday
Bri guy
845
225
This is an example of how my luck is
8,828
7,785
19,993
8,828
7,785
Mine has been shitty too. Plus too much work and every repair a struggle. As said, not sick and have a week+ off. Olds V8 belt set up is hateful and everything must match or it is choas.
  • Sad
Bri guy
845
225
Here you go
This goes on the ps, alt and waterpump? I will do some research and figure out if that will actually work.....that alt bracket was suppose to be a simple add on....but didnt line up. Not sure if im a gambling man again😂 i will have to get measurments of everything and see how it will lines up before i buy this
Bri guy
845
225
Our company is doing a week layoff rotation with all the workers...next week is my turn to hang out at home. Would like the car in 1 piece to enjoy it of the weather is nice
Bri guy
845
225
Is this gonna be an issue?
8,828
7,785
I have the factory passenger side non A/C alternator bracket with billet pulleys, mine line up. Contact them, should work being their alternator bracket.
