Instrument cluster
Mike 86 regal
19
Oklahoma
Ok I bought this regal 86 2 months ago and no gauges works, I changed the fuel sender and speedometer cable and bulbs, nothing works. Checked fuses, took apart the cluster and cleaned and bend the metal parts in on everything so it will be tight, but headlights and turn signal works and check engine light works and that is it. What am I missing?
ELCAM
521
Find the ground for the gauge cluster and make sure it is grounded. If the dash has ever been removed make sure the dash is grounded to the body.
ELCAM
521
Look at the wire bundle coming from the connector(s) coming from the gauge cluster. The ground should be a black wire and come out close to the cluster with an eye terminal on it. It should be screwed to a metal part of the dash.
Mike 86 regal
Thread starter
Apr 17, 2022
19
Oklahoma
ELCAM ok once I feed little man I will see if I can find it, where did you find the wiring diagram at? This regal does not have a tachometer
oldsmobile joe
2,003
mpls
Check your gage fuse. No power, no work.
The lights you mentioned in the first post have their own power.
PJNJ201
42
Hey bud, have you figured it out yet? Let us know. I guarantee what these guys are saying about the ground, is your issue. I had this same problem on mine as well. Ground was the problem!
Mike 86 regal
Thread starter
Apr 17, 2022
19
Oklahoma
PJNJ201 I have not fixed it. I was looking for the black wire and I can't find it, It looks like the person I bought it from changed stuff around
PJNJ201
42
Damn, i see. If you still have it apart, is there any way you can post some pictures of what it looks like behind there? Wires, harnesses, connector etc. and also just out of curiousity, what kind of shape is that green connector film that sits on the back of the speedo in?
