It is easy, until you fugg it up because you bought the wrong switch. There's two different switches because one pulls and one pushes. One's for tilt wheel, the other is for straight column and because they look similar, you can fugg up and get the wrong one. And GM only put them one number apart, which didn't help things. Ignition switch sits right on top of the column. DON'T bend that connector rod that extends down from the key cylinder to the actual switch.
Note- the key tumbler has really not much to do with your ignition issues. Whether the key stays in or not is a function of the ignition switch. If you can turn it, the ignition switch reacts because that's where the wires are. It doesn't care how you turn the tumbler.
TILT WHEEL SWITCH - 1990116 or box store equivalent number
NON-TILT WHEEL SWITCH- GM p/n 1990115 or box store equivalent number
Chek out this post from about 3 months ago showing the difference so you can actually look to make sure it's the right switch. Take the old one with you if you're not sure, or print out the picture of the one you need to inspect the new one.
i have a 1980 olds cutlass Calais and am changing out the switches and relays inside and i am noticing the switches are different than regular g body cars. it took me two months and lots of arguing with salespeople to apprise them of this fact. i just bought the ign switch the other day for a...
gbodyforum.com
