Hi All!
I'm afraid I'm one of many to make my first post a cry for help. I'm at the end of my rope with our 84' Caprice Estate 305. The short story is, I rebuilt the Rochester Quadrajet meticulously, assuring everything was done right, and now she won't run. The car ran before the rebuild, but there was a lot of gas smell in the cabin (hence the rebuild). At this point it'll crank, start to fire and quickly die. It doesn't seem to matter how much or little gas I give it, I'll sometimes get a couple seconds firing and sometimes nothing. When I first spark tested, the spark seemed inconsistent. I bench tested the ignition coil, found it was out of range and replaced it. Now it seems to fire a little stronger, but still won't run for more than 2-3 seconds. Spark test looks great though. I was pretty confident it was getting fuel, because the jets are spraying fine, and at one point I took the carb off after an attempted start, and could see fuel had entered the manifold.
In this whole process I've discovered the source of the fuel smell is from leak back at the filter nut. Worn out threads on the nut (and probably the carb inlet) mean it doesn't seal well. I've tried stacking washers, and using thread tape rated for fuel contact, but nothing stops the leak. Nowhere seems to sell a replacement nut, and I really don't want to get into replacing the carb at this point. Only concern is if it's leaking so much that the engine is starved, but I highly doubt it. Out of desperation, thinking maybe it is short on fuel, I tried a little starter fluid and got no firing at all.
I'm out of ideas, so all suggestions are most welcome!
Thank you
Thank you
