I put the jounce, GP, and f41 front and rear sway bars and core to fender braces on a while ago. Much flatter cornering. Its no corner carved, but it made a noticeable difference. Best cheap suspension upgrade imo. Under $50 if you get lucky at a yard.
I'm glad to hear the F41 bars are a worthwhile upgrade.
Here is a control arm option I left out that is sort of a compromise. If I remember correctly, S10 lower arms will fit, they just need 1/2" bolts instead of whatever size the stock g body bolt is. I could buy new stock style Moog upper and lowers and not have to worry about stripping, cleaning, painting/powdering, pressing bushings in and out. The Moog number is the same for the uppers for G bodies and S10s.
Under $400 on eBay-
Also, does anyone know what the right number is for Moog V6 front coil springs? RockAuto lists like 3 different ones.
Another option on bushings are the problem solver control arm bushings from Moog. They are what I used on my car. They are supposed to last like polyurethane but not be as stiff or squeaky. Supposedly a good compromise.
Jared I think the new Moog arms come with problem solver bushings and ball joints in them.
Reactions: Texas82GP
RockAuto lists 5600, 5606 and 5598 for an 87 Regal with 3.8L V6. For a turbo car they only list 5606.
The 5598 and the 5600 are NON f41 springs without and with a/c and something like 340 or 360 lbs. The 5606 is the F41 spec spring and rated at 420 lbs and it's the only listing for a turbo because f41 was mandatory with the turbo v6 option.
