Tell that to the ***** in the c1500 that slammed on his brakes in the rain for a jwalking goose.Well stop wrecking into sh/t and you won't need them to begin with, Mr. Magoo.
Gotta make the inside match the outside.Man, this thing went from 0-full resto in no time! I thought you were just stabbing in a new motor
Unless there's tunnel damage that's not visible in the pics, I see no reason to replace it. I'd strip it, treat it, and send it.
I got those brackets if they hold on the driveshaft loop. I replaced the floor in my build thread. I went about it just like you are. I made a patch on mine for the area thats rusted on yours. Main thing for me was to get all the rust out of the way. So I could come up with a plan.
Mine didnt make it back to the body mount really. I might have that metal on my parts car. I gutted it last weekend. Ill check and see tommorow. I wont be using it or the dshaft loop brackets.I think it's kinda crusty. I honestly don't remember what it looks like under all the paint. It is usable though it might be easier to just cut it out than to try to grind it smooth and treat the rust.
I thought I was too MrSony's right though, I gotta try to make the inside match the outside. Everything that has paint on it is quality body work, its the stuff you don't see that I need to bring up to par. I'm really trying to get away without touching the paint and I think should be able to do that, but I may wind up loading up the touch up gun, just have to see how it goes. The good thing is that usually once I get into this type of work I move pretty quickly.
Yeah those are the brackets I need. Just like you said, main thing is to get all the rust out of the way so I can come up with a plan. That area in the door jamb is just a little tricky because of the body mount under it and there isn't much access with the frame in the way (although it wouldn't take much to lift it up a few inches at this point... not sure about that though) but I want to make sure that mount is solid. Do you have a link to your build thread?
