I have been wanting a Vortec engine to build for my Monte Carlo for a long time. As some of you already know I found a Vortec core at the salvage yard I work at a few months ago. The engine has just sat around here since Summer. I finally got a price on it a week or two ago, $200. That's complete from intake to oil pan except for the accessories and fuel rail and injectors. I had no idea what kind of shape the engine was in and I know Vortec heads are known to crack so I wanted to look inside the engine before I bought it. Last night I pulled the heads and the oil pan to check it out.
It took forever to find bolts the right size to put the engine on the stand.
Off came the valve covers and intake.
So far everything was looking great. It was very clean inside the engine. Did anyone notice anything out of the ordinary in that last pic? Look again.
Cylinder 7 is missing a pushrod. That's odd. I wonder why it's not there. Pull a lifter, see what the roller looks like.
Not bad.
Pull the heads, see what the cylinders, pistons, and combustion chambers look like.
Some carbon and a little bit of water from sitting outside for months (covered up) but otherwise pretty good.
I scraped some of the carbon off the pistons. The cylinder walls didn't look bad either.
Time to check out the bottom end.
Pretty clean down here too.
Not bad.
