Still wonder why it spit the pushrod out ? A goods clean and a "rattle can" rebuild and you should have a good little motor on your hands
my guess is the valve is seized and rocker arm won the fight
It looks like you saw the worst of it and it looks good. Looks like 062 heads and along with the block heater would say it from a truck. I would also guess that it has been apart - someone correct me if I'm wrong - it looks like a felpro oil pan gasket and the blue on the heads would indicate felpro gaskets there(plus brass plugs). The pistons don't indicate over bore(check it) and you have PM rods. Engine probably got shut when the push rod created the noise and the engine ran crappy. looks like the spider tray and the guide held the lifter in place. Your probably right about getting it running.
Sounds like a possibility. I haven't given the heads a thorough check yet. Other than that, what else could have caused the pushrod failure? Rocker arm nut too tight?
I agree. That is a bit of a conundrum. Also, why would only one pushrod be affected?Still wonder why it spit the pushrod out ? A goods clean and a "rattle can" rebuild and you should have a good little motor on your hands
I guess it could be attributed to either a rocker arm locknut that prematurely loosened up, a rocker stud that pulled out, but you more than likely would've discovered that...a defective self aligning rocker arm..? I'm just running across the possibilities. I suppose even a defective pushrod could be a consideration.
