I don't think you're correct in that the valve being adjusted to tight is the cause of the bent/bending pushrods. Get the valve spring off and remove the valve. Something else is up there IMO. With no preload on the lifter there should be no way the pushrod should bend. If you adjusted the valve to tight, then the valve should open once the lifter bottoms out.
X2 with the valve is stuck, or possibly bent. I couldn't see in the pic, but is that valve tuliped?
Post some pics of the valve please
I plan on doing a complete tear down when I get the engine home and get the garage cleaned out. I've already left the shop for tonight. The only pic I have right now is of the combustion chambers with the valves installed.
Cyl. 1 is the one with rust from water getting inside. Cyl. 7 is the one that's had pushrod problems.
