Got my new B body booster on and just test drove it.
I didn't fix the issue so it wasn't the old booster being the problem. I figured the chances were that high though.
The bigger booster made my problem even more pronounced. Upon starting in park I noticed that the pedal was easy to just push down all the way to just off the floor. A definite stop in the pedal is felt so it's just plain as far as it will go.
It will not pump up at all if I pump it rapidly. Goes to the floor with every push.
During the test drive, the pedal would remain high during a normal type stop. Just like before. But even for a moderately aggressive stop, the pedal would then feel mushy and move to far and it did this easier than before. After depressing the pedal to what feels to far, It also lagged coming back up after releasing my foot. It didn't do that before. Could be because the foam insert that the pedal rod goes through inside the boot was completely disintegrated from age.
Seems like I've got to either have air in the system or a bad master and just have to find out which one it is. Dang, I was sure I bled the bench bled the master perfectly and did a diligent job of power bleeding when doing the wheels. I've been doing my own brake jobs for 45 years and never had an issue like this before.
Not sure what to do next but I'm thinking I should pull the master and put it back in my bench vise and test using Dave's method. I don't have the plugs but can make them. I've got 2 steel tube nuts that are the right size and I can weld the holes up with my mig welder.
Since I am pretty confident in my bleed job, I'm inclined to think the master is bad even though it is a new Centric. If I take the master off, I can not only check it to see if it's bad (with the plugs) but I can also see if maybe I somehow didn't get it bled all the way.
That seems to make more sense then just re-bleeding at the wheels first. Not sure though.
I'm not keen on clamping my brake hoses to see what happens. I just keep thinking that wouldn't be good for the hoses. And not sure it will really give me the answer between air or bad master.
Comments will be appreciated Dave.
