Â
You can get them with a 340lph pump too 😉
Have to stop surfin' the lemonade stands for yellow bikinis to find items like theseI had no idea that even existed..
If you need that much pump and power for 10's something isn't right...I needed two fo-fiddies (450's) for corn on 58base plus 12 for boost compensation and I'm only making 10 second power :0
Jake's right, a single 450 is very difficult to get a 3500+lb vehicle into the 10's with more than 10 psi of boost. NA it could be done, but the boost deal requires more pump. At least imho. One thing that is often overlooked in these calculations is the additional fuel pressure needed to maintain the same amount of fuel delivery as an NA vehicle requires to make the same BSHP. The pumps become less efficient as the pressure increases.If you need that much pump and power for 10's something isn't right...
