#7 Rod spun it's bearings in my lil 350 (my fault entirely), and it scarred the crank pretty bad. Toasted the bearings on that journal for 7 and 8 as well. Now, I know I have to have the crank turned, I'm gonna go ahead and get it done on the mains as well as the rod journals. Now, the questions I have is are: are my rods bad since the bearings spun in them, and are the bolts bad? I noticed they were pretty damn hard to get broke loose, although the I torqued them to spec at 40 ftlbs when I built the motor. To my understanding, rod bolts can stretch when the bearings go bad thus rendering the bolts useless and the rods potentially garbage... correct? The cap was still tight and flush against the rod end, nothing was loose or flopping about. Is there anyway to check the stretch using simple hand tools, or does a machine shop have to decide?
