The valve train was making noise after some time. I broke it in for 40 minutes, at 2000, 2500, and back to 2000. No noise. Drove the car 5 miles, no noise. Drove it another 2, faint tapping from the top end, indicating lack of oil. Installed the plugs, tapping went away and had 50psi cold at idle, 23 when hot. 23 hot at 800rpm idle upto 2500rpm or so, then from 3-6,000 a steady 60psi. I used moly graphite lube paste on every bearing surface, the cam, and the lifters pushrods and rockers. I think that stuff saved my engine. On Buick 350s the 7 and 8 rods are the LAST things to get oil. And my engine is basically stock. Only thing I've done to it is a .030 overbore, new cam, and swapped from a two barrel to a 4. As weird as it sounds, it wasn't the no oil pressure break in and drive, it wasn't the being boiled alive twice, it wasn't the almost frozen solid, it was 6k rpm and prolonged runs at WOT at 5500+ that killed the motor. It was a me problem.
