RUDE DOG said:Are you going to keep the harnesse's fuse and relay center and just power everything from there to make it appear stock, or are you going to splice things up.
ATL Regal said:RUDE DOG said:Are you going to keep the harnesse's fuse and relay center and just power everything from there to make it appear stock, or are you going to splice things up.
This is exactly what I want to do, keep the harness and fuse & relay box STOCK. I hadn't planned on touching it at all, don't want to.
But now I'm wondering if keeping them stock is even possible.
I don't know how to rewire a fuse & relay box and have no desire to.
Doober said:It won't fit with the headers bolted up. Easiest way to get the headers in is remove both the starter and oil filter and install from underneath, one side at a time. Don't bolt them up until you install the starter at least, it'll make things a little easier. If you want to go a step farther, unbolt the steering column from the steering box and move it over some.
Is keeping the underhood fuse & relay box stock possible???nova_rookie said:ATL Regal said:RUDE DOG said:Are you going to keep the harnesse's fuse and relay center and just power everything from there to make it appear stock, or are you going to splice things up.
I think your best and cheapest option is to get an aftermarket harness. I believe the cheapest is from Howell:
http://howellefi.com/gm-vortec-products ... 3-4-5.html
nova_rookie said:I don't think so. There has to be some modifications. For instance, the L31 underhood fuse box has fuses for heated seats. I don't have heated seats in my Nova and I doubt you have heated seats in your Regal so you would have to remove those wires. I modified those circuits to provide power to my new electric fans-- I had to add relays to the relay box since the L31 has a clutch fan.
Essentially, I have two relay and fuses boxes:
Nova original fuse box- everything this fuse box supplies is original to the car-- horn, taillights, brake lights, radio, etc.
L31 fuse box- this supplies everything I added with the engine swap-- fuel pump, computer, electric fans, etc.
The L31 fuse box requires only two interfaces with the original electrical system: 1) it needs +12V from the battery [computer gets power at all times] and 2) it needs +12V during START and RUN [loads such as fuel pump and electric fans]. That's it, no other interface with the original wiring harness is required to get the engine running. Some additional wires from the L31 harness may be required to get your instruments to work (tach, speedometer).
I suppose you could go through each load in the L31 and see if it is function you intend to use. For instance the L31 has a horn relay (which I converted to another function) as does your Regal fuse box. You would have to find the four wires going to the Regal horn relay and move them to the L31 horn relay. The L31 underhood fuse box does not contain all the circuits your Regal fuse box does (radio, lights, etc.) so you have to keep the Regal fuse box anyway or severely modify the L31 fuse box.
Rather than trying to integrate the two fuse boxes, it is much simplier to envision them as two separate devices. The stand-alone wiring harnesses (like the one in my previous post) adds a fuel pump relay and appropriate fuses, they are just not put in a box.
I'm 95% sure of this. The headers have to go up from under the car with the oil filter and starter removed... at least it was easiest this way on mine, and I did 1 side at a time, jacking the car way up in the air... a little nerve racking really.ATL Regal said:Doober said:It won't fit with the headers bolted up. Easiest way to get the headers in is remove both the starter and oil filter and install from underneath, one side at a time. Don't bolt them up until you install the starter at least, it'll make things a little easier. If you want to go a step farther, unbolt the steering column from the steering box and move it over some.
You're saying that the engine and trans won't fit back in with the headers bolted on?
