I got the rear brake lines and hoses installed, bled the system and it gushed fluid outta the rubber hose union. I had to cut off the metric bubble flare nuts and put in double flare standard nuts to connect to the rubber hose union as this car doesn't have traction control like the TA would have had which this kit is for.
After much fuss I found the culprit, the new tube nut was bad, the center hole was not centered to the thread and it didn't allow the flare to seat. Great.. cut that nut off and re flared and we're back in business. Still gotta do the front but we have rear brakes.
Cut down my rails to fit the tee on the driver's rear and finally figured out my fuel rail return on the passenger side.
Rest of the fuel system fittings are on order.
