LED Conversion Odd situation
Locus2298
12
Hello fellas and felletes,
I did the led conversion on my 86 MC CL. Turn signals, parking lights, you name it, all LED. I bought the Novita HD12 flashers, which, when in daylight and car lighting is off, both turn and hazard work like charm. However, if I turn on my lights, let’s say going out for a night ride, just the hazard works, the turn signals does nothing. Something that is interesting is that, when all the lights are on and I activate the hazards, the third brake light “blinks” as well in perfect harmony. Is the third brake light causing this issue? Again, just happens with the turn signals and just when all the other lights are on. Thanks!
The third brake light bulb I used is a 2 contact led bulb. Just wanted to point that.
ELCAM
859
It's probably the Novita HD12 flasher it doesn't work with all LED setups properly. Try a CEC EF32RL and use the ground wire.
