oldiejams said:Qdub24 said:oldiejams said:assuming all stock suspension is intact how would 24s fit on a gbody?
i wanted to ride a little high, but i don't really want to get a lift
With brand new stock V8 springs & shocks and the lowest profile 24" tires (25 series) you can get, they should bolt right up. You may need to roll the wheelwell lips for a little more clearance, and/or trim a bit of the front fenders to turn the wheels.
thanks bro
the v8 springs will be cool with a v8 in the car though right? or is it a rule to get heavier duty springs than you need for your application if you want to ride on big rims
like:
231 with small block v8 springs
350 with big block springs?
or new v8 springs with v8 engine is ok?
Either should work, as long as there are brand new springs and shocks installed. Most people just go waste money on an expensive lift kit w/o ever replacing their old, worn springs and shocks.
