lock tight
jlat
250
61
hello people: Do any of youz use it? I got use to using it on my bike and messing with my 86 T today it got me thinking. LIke power steering pump bolts, alternator, IC bolts and on.
IBBY
ck80
5,743
9,123
IBBY
Some places it's more appropriate than others. If you do use it it's important to buy the right grade (color) for your application.
Some people go to wally world and don't realize all the different grades that exist, but aren't stocked in a big box retail store...
mikester
2,928
3,721
Small town NY
I use blue loctite a lot. Depends on the application. I will say I use anti seize a lot more. Especially steel into aluminum.
5,716
12,233
Be careful with some of it. Green is silly, somewhat like welding a nut in a bolt.
Blue is generally what is needed to keep nuts from ‘falling’ off.
Ribbedroof
4,924
7,060
Wellston, OK
The proper fastener, properly torqued, is sufficient for most tasks. Loctite has it's uses, but too many people think it's the answer for everything, IMO.
mikester
2,928
3,721
Small town NY
Ive seen suspensions put together with hardware store bolts and nylocks. SMH
Over the years Ive had to buy quite a decent amount of 10.9 bolts, matching washers and prevailing torque lock nuts. Didnt need much loctite with them but in a few spots I still put a drop of blue on the bolts. LOL
melloelky
4,175
9,606
mass
I've used it on smalls that are in a tough spot before. I'm proned to use anti seize on just about everything though.im not much help with this one afterall.
79 GP 4 speed
448
536
I use blue loctite when I feel it's needed and antiseize when needed. Antiseize is one of those products you look at and you have it on your body and clothes without even touching it.
melloelky
4,175
9,606
mass
the food grade isn't nearly as contagious as the aluminum..I don't know how but it doesn't travel
