The install is easy, just need to 'notch' with a (die grinder or dremel) the bottom of the steering column shaft so the bolt passes. Never shipped anything to Tahiti?? If you can find a late 90's- 2005 Astro or Safari van there, the shaft modification isn't too bad. Just need a welder to weld the knuckle back on. I can check on shipping if you want?
