lowered front and 235 60 tires
mickeypowa
mickeypowa
137
Tahiti - French Polynesia
Hi !!
I changed my front tires recently by 235 60 15 (the original tire size I think ?) but now the tire hit the frame. It's because the front of my car has been lowered I think.
I would like to keep theses tires without trimming, so I would like to go back to a stock height. How can I do ? What parts should I change ?
The springs, and the shocks ? other parts ??
Do you have the references so I can order on internet ?
Thanks a lot !
Mickeypowa
Winkernod
Winkernod
138
London Ontario
My 1980 Grand Prix is at stock ride height but when I put 235-60-15 on it the inside scrubbed slightly so I had a pair of 1/4 inch spacers that fixed the issue
P
PBGBodyFan
403
Wisconsin
Hits with normal driving or on full lock turns?
mickeypowa
mickeypowa
137
235 60 15 isn t the stock tire size ?
It rubs the body frame at full lock turns, but a lot !
Actually I bought the car already lowered with 225 50 15 tires. So I didnt do a wheel alignment.
But as the roads here in tahiti are pretty bad, I would like to have stock height and tires to have a more confortable car.
And I prefer the standard height aesthetics.
What should I buy?
Moog springs ? Which one ? And shocks ?
Or also other parts ?
MechMan
MechMan
290
Long Island NY
I know that the stock tires on a 1986 Monte Carlo SS were 215/65/15. I don't see stock for yours being too much different though I am not sure what you have. Looks like a Grand Prix from the picture.
pagrunt
pagrunt
5,560
Elderton, Pa
I had a few years between putting in new springs (non-A/C SS listing) & putting on the 235/60/15's with the change vrom a V6 to V8. There was never any rubbing with the tires & the inner fenders/wheel lip. The only factor that could be different for me was I used mid '80's steel rallys that had a different a different offset than the stock 14's & let the wheel wieghts hit the lower control arm. Might want to see if it's the offset is the cause.
mickeypowa
mickeypowa
137
Ah yes I have not the stock rims too. 15 inch but I don't know the offset.
But in fact the tire is too tall and touches de metal of the frame. If I put a spacer the tire should be stuck against the frame.
I switched to 205 60 15 and now I don't rub anymore, but I m not satisfied of the aesthetics.
What coil springs and shocks would you recommand for my oldsmobile cutlass supreme 1980 ?
Should I change the control arms etc too?
The photo is with my new 205 60 15 !
O
Oldcoyote
14
Hi !!
Thanks a lot !
Mickeypowa
How was the front lowered?
pagrunt
pagrunt
5,560
Elderton, Pa
Hate to see you wasing money of tires but a 215/65/15 might be what would work for the aesthetics. This is the stock 15 inch tire for our cars (MC SS, 442, GN, 2+2).
Thread starter Similar threads Forum Replies Date
S MONTE CARLO 22 irocs lowered Wheels / Tires / Brakes 5
houston_t Rear to front brake line. Wheels / Tires / Brakes 1
Hippi 78-81 Malibu lemans inner front fenders G-Body Parts For Sale / Trade 2
BronzeLemans78 Front & Rear Bumper Trim - 78 Lemans Pontiac Grand Prix/Grand Am/LeMans/Bonneville 6
Rus Front shoulder belt removal Interior 3
S In desparate need of a passenger front wheel well moulding/trim w/2 tone paint for my 85 ElCo Wanted 3
R 1999-2003 front steering knuckles Wanted 11
Olds G's 1984 G47 Front Fender Lower Trim Oldsmobile Cutlass / 442 / Hurst/Olds 4
nickonometry Cutlass front spoiler options Oldsmobile Cutlass / 442 / Hurst/Olds 1
CDUNIGAN1981 Kore3 C5 Front and Rear question Wheels / Tires / Brakes 16
350Cutty **Moving Sale - Cutlass Front End $50. G-Body Parts For Sale / Trade 9
Tyler l Front clip change General Discussion 1
cruize1 WANTED 1985 MONTE CARLO FRONT BUMPER SIDE MOLDING Wanted 24
Kelvin's80442 Front suspension,crossmember,hood 80 442 Wanted 8
7 NOS LeMans Front Bumper Cover/Header Panel G-Body Parts For Sale / Trade 0
M Front air dam Wanted 3
airboatgreg Front Shocks General Discussion 9
H Questions on parts for 87 442 front turn signal gasket and wiring cover Oldsmobile Cutlass / 442 / Hurst/Olds 2
J Aftermarket hurst front spoiler General Discussion 1
P 1980 Cutlass Supreme Front Bumper G-Body Parts For Sale / Trade 0
S Looking for passenger side front wheel well molding w/2 tone paint for my 85 El Camino Body / Trim / Paint / Glass 0
P 1981 LeMans front end G-Body Parts For Sale / Trade 2
M 84 cutlass.Need front license plate holder Body / Trim / Paint / Glass 0
K CUTLASS Front bumper badge Body / Trim / Paint / Glass 2
gnvair 15" Front tire sizes that will not rub Chevrolet Monte Carlo / SS / Malibu 15
P Sway Bars - Front 34mm hollow (f-body) G-Body Parts For Sale / Trade 8
K NIB Spohn Front upper Tubular Control Arms 1978-1987 GM G-Body G-Body Parts For Sale / Trade 8
I Front Springs Frame / Chassis / Suspension / Steering 1
565bbchevy Front backing plates new General Discussion 5
Tim & sleek Front brackets General Discussion 7
Cajun83HO LS front crank seal replacement General Discussion 7
J front end parts? Frame / Chassis / Suspension / Steering 5
J Front license plat bracket? Oldsmobile Cutlass / 442 / Hurst/Olds 28
Wageslave Best front end changes for high speed stability? Frame / Chassis / Suspension / Steering 20
V Front suspension race car Frame / Chassis / Suspension / Steering 5
R ?? Front body mount replacement Body / Trim / Paint / Glass 0
O Wanted 1981 Olds Cutlass front license plate holder Oldsmobile Cutlass / 442 / Hurst/Olds 0
abstracts18 G Body Front air dam/splitter help Oldsmobile Cutlass / 442 / Hurst/Olds 3
gnvair Can anyone definitively say that the front lower control arms from an S10 will work on a 78-88 A/G body?; Frame / Chassis / Suspension / Steering 22
B Adding front spoiler/splitter to Monte SS nose General Discussion 2
Mikko F-Body Hollow front sway bar install help Frame / Chassis / Suspension / Steering 7
Macguyver Autocross ready front end kit! Autocross 1
I Front end replacement parts Frame / Chassis / Suspension / Steering 2
H Need 87 442 front bumper cover decal and stripe Oldsmobile Cutlass / 442 / Hurst/Olds 5
D Front sway bar problem Frame / Chassis / Suspension / Steering 8
D Front spring install suggestions Frame / Chassis / Suspension / Steering 28
G Finding Front-Axle Center line Frame / Chassis / Suspension / Steering 15
H CUTLASS Front sway bar bushing bolt mount stripped Frame / Chassis / Suspension / Steering 34
L MALIBU Front suspension hardware Frame / Chassis / Suspension / Steering 2
D Front suspension???? Frame / Chassis / Suspension / Steering 35
Similar threads
