Depending on exactly what you want, exactly where you're going to source it, and exactly who is going to do the work for you, you may find yourself blowing right past your $10,000.00 budget. Kep in mind, its not just installing the engine in the car. What transmission do you want to use? Are you going to keep the engine fuel injected? If so, how to you want to have the fuel system set up? How are you going to run the wiring? What type of cooling system will you be using? What type of engine accessory drive will you be using? What type of exhaust system will you be using? Will The power level that you're looking for require other driveline, braking, or suspension changes? The rabbit hole that you're looking into can be very deep. Make sure you research it carefully, before you proceed.
