LS Swap with TKO 500/600
atvjoey
10
North Jersey
So I have an 87 El Camino that I put a brand new sbc 350 in it with a 2.73 open diff and a th350 to build a daily driver. it has been great but I am quickly realizing the limitations to what I thought would be a good daily driver. I do have access to another car while this swap happens but I have always wanted to convert it to manual. The problem is I want this to be a daily driver that also can at least run a respectable 1/4 mile. maybe high 13s. So I met a guy that did an LS swap and I am all over that but I also want to do a tremec tko 600 swap. I have had almost exclusively stick cars and I desperately want to turn my elky into one. Has anyone ever done this swap? I have heard of the ls with the t-56 but I am not willing to do that since I am trying to save money and I got a good deal on a tko 600. What would be involved with the swap? specifically the crossmember? Is an ls the same length as a sbc because I know they make a crossmember that can fit it. Anybody that has done the swap or something similar please leave some info because I have not seen anybody do it. I consider myself very mechanically inclined but the only thing I cannot do is welding so everything has to be bolt in. On a side not, is it possible to maintain AC with an ls swap? I have the ac box but nothing hooked up but I definitely want it now after a couple 100+ degree days. Thanks guys for any help
ssn696
Living in the Past
Jul 19, 2009
5,448
6,450
Permanent Temporary
Streetbu
Know it all, that doesn't
May 22, 2011
3,590
10,936
Central NY
If you're not comfortable doing fabrication, I would suggest you DON'T LS swap or especially TKO swap you're vehicle. Because I GUARANTEE you'll be making all sorts of parts to get to work all together. Mainly the crossmember, exhaust, and clutch pedal/hydraulics just to name a few.
atvjoey
10
North Jersey
I have been doing a bunch of research and there a places that sell everything bolt in for both swaps I am trying to see if I can basically mash them together. I have manual swapped other vehicles done basic engine swaps (v6 to v8) but I am just bad at welding so I would rather spend the money on quality parts. For anybody interested six speed monte sells the bolt in hydraulic clutch swap kit and Holley sells the ls swap parts. I know its possible because I know a guy that did it himself in NY (albeit expensive) but possible to do without and serious fabrication
atvjoey
10
North Jersey
I am not deadset on the idea but I think making a reliable classic v8 daily driver would be very cool. I would probably do the tko swap first and then adapt it to the ls if that's the way I decide to go but the 11mpg I get with my mild 350 as opposed to the 21mpg that a buddy of mine gets in his ls swap is killing me for a daily especially if since I plan to keep this car for many years
Streetbu
May 22, 2011
3,590
10,936
Central NY
Well, I bought everything "bolt-in" for my swap. And most of it didn't. Especially the clutch linkage that I'm still fighting with...
08Malibu
1,229
2,607
North Jersey
Just swapping to an overdrive will up your mpg.
Malihoochie-
May 14, 2020
50
76
Detroit area
I put a TKO600 in my Malibu and it was not a big hassle. I did have to modify the Z bar drastically ( a hyd throw out bearing would eliminate that) because I used a standard/regular GM type bellowing. The G body bell housing was specific to our cars and also required a special fork. I used a std clutch fork and trimmed a little off it and put a little dent in the floorboard, later on I changed the body bushings to poly ones and I think no mods would have been needed to the floor or fork, if I done the bushings first.
