I have to 2nd your statement on traction issues with the 3:73's and 3400 stall in my 80E. I just left a car show and for some odd reason the tires just decided to start spinning. Next thing I knew there was smoke and I was accelerating at a high rate 😁!!!I put an 4L80 In my 442. NO tunnel work is required and cooler lines are accessible. As noted you will need a saws all to cut the sides of the trans housing for header / exhaust clearance. My car has the factory 3.73 8.5 rear end and first gear is definitely not too long. I have major traction issues and wish gearing was taller. Your 3:42’s should improve this. I’ve read that some dyno comparisons between a 4L60 and 80 show minimal difference in parasitic loss.
Weird how that happens, I have the same issue sometimes.I have to 2nd your statement on traction issues with the 3:73's and 3400 stall in my 80E. I just left a car show and for some odd reason the tires just decided to start spinning. Next thing I knew there was smoke and I was accelerating at a high rate 😁!!!
I don't like the gearing in either of these transmissions. With all the mods needed to fit a 4L80E under my 70 plus at least a $500 core which still might need rebuilt, bell housing adapter, a controller and an expensive converter, a TH2004R with mods is my choice. But as said, if you have the power where a TH400 or 4L80E is needed, their tall gearing and .75 OD gear in the latter's case won't matter as much. If anything you want the 2500 rpm highway rpm with a big cam. I figure 70 mph for me will be perfect, around 2200 rpm. I am surprised any truck converter will stall at 2000 rpm plus, most stall around 1500 rpm for towing. Probably because a 3/4 ton with a 350 needs the higher stall to get out of it's own way.
