I like your CTS-V. Nice set up. Base engine for the Avalanche is a low mileage LY6 with ported L92's, long tubes, and custom grind cam. The 100 hp I was referring to is an E85 specific tune which personally I am not excited about because according to my tuner you shouldn't run regular pump gas with it. When we have Dyno results I will post them.
Thank you. Why shouldn't you run pump gas? All LS motors are made to run on pump gas. As long as you have a flex fuel sensor it will be able to adjust accordingly. Now if its tuned for just e85 and no flex sensor, then yes i wouldn't run pump gas. DMS makes one of the best flex fuel sensors you can buy. I run DMS's flex fuel sensor and ID 1050X injectors and love it. I can drive the car anywhere and not have to worry about mapping out all the places with E85.
