Westbank of NOLA said:Okay, I'm jumping right into the fire. Has anyone considered doing a LQ4 or LQ9 swap as a poor man LS1 upgrade. My family is trying to talk me into saving money and time hunting by going with a LQ4 out of a Chevy Suburban 2500 thats been wrecked. I'm barley on the LS1 information level, now I need to research LQ4. Seen that its based on the LS1
OK I just did the the 5.7 aluminum ls1 swap and am planning on either a 370 or 408 Iron block lq4 build which is basically the same architecture as the 5.7 only differences between are besides the iron being stronger are,
1. iron vs aluminum which is 80 or so pounds weight difference....
2. 364 ci lq4 or lq9 vs 346 ls1& ls6
3. lq4 0r 9 are cheaper then a ls1& ls6..... lq9 are bit more seeing as they are the HP version of the lq4
4. lq4 has dished pistons vs lq9 flat top pistons
5. both Lq series use the same heads casting number 317 which is basically a 243 head with larger cc chambers which from which I gather are good heads for forced induction ie: turbo! early model lq series you want to avoid due to iron heads and a different crank snout.. I believe 99-01 6.0 I believe..
6. from I gather 243 heads or there twin heads 799 work great on a flat piston lq series engine once milled and matched to the pistons, cam, etc etc...
7. f body accessory drive will mount to a lq4 or 9 with the drilling of the block to accept the alt bracket
http://ls1tech.com/forums/conversions-h ... r-diy.html
or you can mod the truck accessories to the ls6 intake
http://www.performancetrucks.net/forums ... ap-359987/
basically what my plan is to disguise my lq4 to be a HP lq9 and look like a ls1...... this is all I have for now some info could be bad let me know I don't want to spread bad info! If I could I would to a 408 lq with a LS3 top end and but I don't know bout dbw... :!:
NOW there different variants of the 6.0+ 6.2 ls2, ls3 L76, LY6, L92 etc etc.... LS1tech is a very good tech site! research and do more research and you will find what you seek..
