LSx Swap Parts Database
motorholmes
375
16
I figured it would be nice to have a thread where a guy can find all the part #s and what works. Feel free to pitch in if you guys have some stuff to add.
Coolant Temp Sender (98 Camaro 3-wire) 12551708 or TX111
(I don't have the part # for the pigtail, but they're quite common in '99-up cars+ trucks. My Ebay item # was 120777784118)
(I also don't have any part #s for the oil pressure adapter)
B&M TC lockup controller 70244
If you use the Hooker cast LS1 exhaust manifolds you can use steel 2.5" flanges- Patriot H7265 $10.95 w/gaskets! I think you might be able to use these flanges on a set of Ls1 Camaro exhaust manifolds too... (?)
TCI flywheel Speedway item # 282399753 ( the price on this keeps going up and up)
Lokar dipstick Speeday item# 4915008
A/C compressor and alternator: I used a 1991 Camaro 5.7 compressor and a 1996 Chevy 5.7 truck alternator (alt fits LS bracket)
More to come
Awesome idea, I subscribed! I currently get 8 mpg.....I predict I'll go LSx in the near future, lol
YOUR RESULTS MAY VARY! These are my part numbers for LS truck motor to G body:
Cheap headers that worked for me (pass side needed hammering) Pacesetter 702256
Dual Plane intake and MSD combo kit Edelbrock 7118
Smaller P/S pulley to clear steering box Dorman 300-201
Crank spacer for curved flexplates GM 12563532
LS1 motor mounts: 1” setback – will need new holes drilled in K member Trans Dapt 4516
165 deg thermostat SLE 100223
There is a perfect “U” hose for the water pump - if you want to bypass the heater Dayco # 87629 or Kelly-Springfield #S-4354
All you rich guys disregard this:
When I am looking to buy, I Google the part number and then hit the "shopping" button, then the "sort by price" button. Some of the smaller speed shops have HUGE markup.
Reactions: Scotty t
:lol: :lol:
I don't think there a whole lot of those around here! Maybe retards like me who buy crap and then find out I could have done it much cheaper if I was paying attention! :roll:
Pacesetter headers DO NOT work with the BRP mounts. I beleive the only headers that will bolt in are the BRP's.
Northern radiator makes a cheap alternative radiator vs the Be Cool and other high price brands for same side inlet/outlet aluminum radiators
A couple combinations that work
BRP engine mounts
Iceman 4L60E crossmember
BRP headers
Musclecar pan/Holley pan
Setback mounts
Iceman crossmember
F-body Pacesetter headers
CTS-V/narrowed F-body/truck
If you need to use the dished flexplate for your LS swap and are using a 4L60E, don't bother with a GM flexplate
http://www.converter.cc/product_p/sfi-ls1.htm
A good mod is an oil catch can instead of the crappy PCV these engines had. Regardless of what is done or what you are planning to do it's a mod worth it's weight in oil :lol:
http://sdparts.com/details/mnmpcvccbk
Intake couplers and pipes from here
www.intakehoses.com
Airaid makes an awesome product for people like us custom engine swappers with this "universal" intake tube. Really nice piece actually
http://www.ebay.com/sch/i.html?_trksid= ... d&_sacat=0
For anyone in the process of their build and planning on going to a FAST intake in the future, upgrade your MAF now and save money later. Here's two things you can buy to make yourself a 100mm fast for half what others charge for pre-made ones. Just convert your 3/5 wire to the LS7 schematic and get your car retuned and your good. The MAF is cheaper at a dealership I just wanted to put a link up
http://www.ebay.com/itm/Spectre-Perform ... 95&vxp=mtr
http://www.ebay.com/itm/LS7-LS3-Corvett ... 5f&vxp=mtr
Ill just keep adding more I'm bored and still waiting for my trans and converter to return
just joined today because i may be getting a 79 supreme and have a ls6 ima drop in it but ne ways, stumbled upon this thread and love it already!! what about wiring the dash gauges to the ecm so everything works properly???
You'll have to track down each person's build thread and follow along. I think the EFI guys are using a speed-density tune and either running a 700r4 with a cable to the speedo, or 4l60e with aftermarket gauges. I'm not real sure on that though. I did a carb on mine this time.
Where'd u find a LS6? They're kinda hard to come by
