dogshit said:Can the wagon floorboard be modded to allow the GN tank? Its generally a lot better cheaper easier and safer than doing a sump and having a gravity fed electric pump hanging between your tank and bumper. BTW fwiw the Monte had a 4.3 TBI the Buick had the 3.8 SPFI, sequential port instead of throttle body.
Buy a sump from jegs or summit. I drained my tank and followed direction on drilling holes. Then i took it to a local radiator repair shop and had them braze it in.bfreehill said:Thanks for the reply's..
yeah I thought about the floor mod for a moment but not worth the loss of the spare tire.
What is involved in the sumped tank?
welding in a new outlet at the bottom?
I thought I might look into small pickup tanks, may be a good fit for side fill and narrow.
I see your point but i have a sumped tank on my wagon and nothing hangs anylower then the spare tire hole. With the wagon you can come out of tank and run a alluminum line almost do a 180 bend and put line between tank and tire hole and hide pump on front side of tire well tucked up and away nothing to get hit. The sump on tAnk if done right wont get hit unless he puts it on back bumper because its only like 2" below the bumper. Still higher then the lowest point of spare tire well. Wagon tank sumped hangs down nothing like a regular gbody tank when its sumped. Also if your worried about getting rearended and something happening at this point with a wagon car is destroyed anyway. And i dont see a sump causeing a fire any worse then a normal gas tank. A crushed tank is a crushed tank.dogshit said:Have been involved in a few of both. At minimum easier safer quieter and less likely to fail. Stealth to, no pump hanging out back for a run through the ditch to rip it out or to get smashed and burn a car in a rear end collision. Seen it happen at National Trail raceway in Columbus to a beautiful GS that was at the back of the line waiting to get off to go to the races. No problem on an old skool drag car conversion but not a fan for the street. Just my opinion.
