Got the pump power supply issue sorted out and was able to start and run it without needing to hot wire the pump. Additionally, we discovered It was running rich and not holding pressure at the rail after shutdown so the assumption was leaky injectors. Pulled the rail with injectors attached and put it under pressure. Sure enough, #1 injector was a gusher. Luckily I have a set of injectors from my 96 vette on the shelf that only have about 50k miles on them. Slapped them in and we're doing much better now. There's a check engine light recurring and I'm gonna tackle that today. Here's a short vid of startup with a few throttle thumps.
