LT1 swap - Which cam?
willie
n00b
Nov 15, 2008
Swapping LT1 from '94 buick roadmaster with ported OE Iron heads into '87 regal. For those that have done this and used Iron heads and not Alumininum f-body heads, what cams can be used? This car will be used for street and strip and emissions is not an issue. When I run camquest, it says machining to the heads will be necessary...whats the specifics on the machining required?
