MAF vs. Speed density
ryanwitski
296
OH
I eventually want to switch to TPI on my elky. My question is what is the difference between MAF and the speed density. I heard speed density only works with 700R. The MAF looks kinda ugly (but then again I have a hood to hide it all. lol.) also I know the speed density has something to do with the speedometer or something like that. I eventually want some type of forced induction and the MAF wouldn't work. I need the earlier TPI but does it have to be converted to speed density so i can put on a forced induction (TT, projection etc... .). Will it work?! I've seen it but EXACTLY how is it done?
the difference between MAF and speed density is
1-maf was from 85-87, speed density was from 88- on
2-you need a chip if you do any modifications to speed density (MAf will compensate up to 12% performance improvement)
3-you can convert MAF to S D if you change the computer and block off the 9th injector
4-if you get a chip burned for SD it will work better than if you just modify a MAF setup
5-removing the screen and cutting the cooling fins down on the MAf unit will improve flow
6- removing the casting blocks behind the throttle body, installing an AEROFOIL in the the throttle body, getting a cold air kit with smooth bellows in place of the factry corrugated hose, and installing and setting up an adjustable fuel bressure regulator will give you a 7 tenths improvement in both MAF and SD setups
7- factory TPI setups were designed for 305 engines, 350's were used from 87 on and the same intake was used hindering top end performance on the bigger cube engine
8- if you want lots of torque and dont plan on going over 6500 rpm a TPI will work for you
9- if you already have a TPI setup you can buy the aftermarket upper, lower, and runners and be able to go up to 7000 and sometimes beyond
10- both setups are usable with 700 trannys
11- SD has nothing to do with the speedo
12- you are better off using SD when going the turbo/supercharger route either way you will still need a chip burnt for it.
hope this stuff helps. 😀
WOW! that was awesome! thanks you answered all my questions!
😢 i am too poor to do it, so i read alot and help my rich friends with their cars :wink: lol.
