Bonnewagon
Do the boot last after everything is in place. The push rod may not end up where you think it will.
Ok then the hole i drill should be smaller than 2" by the sounds of it? Boot is barely 2"Do the boot last after everything is in place. The push rod may not end up where you think it will.
Very helpful. I will be using this for the install. Got transmission in tonight. Getting closeHere is an additional pic from my '80 olds manual. Linkage is the same as chevy
The red circled washer is the felt washer, the spring is used to lock the ball stud & plastic bushings into the end of the Z bar.Question … see the pic.
Is the “washer” (red) the big felt washer?
Is the “spring” (blue) just a lock washer?
My Z bar has a hole tapped in the middle of the round shaft. Is this for a grease fitting? If so am i supposed to pump it full of grease?
I just looked it up in my '79 Cutlass assembly manual & it shows the same grease spec & p/n's for the grease, felt washer & spring. This one uses metric numbers & calls for .001 kgs of graphite grease for the ball studs & .005 kgs of grease for the rods.Sorry all I have is a Corvette assy. manual with this info.
I have seen the hole with a plug and a zerk fitting.
The linkage rod ends get chassis grease and the pivot bar gets graphite grease.
Oh yes, I put the spring in the groove.The red circled washer is the felt washer, the spring is used to lock the ball stud & plastic bushings into the end of the Z bar.
They used a plastic plug in the grease holewhen the cars were built, packed with a heavy grease. I put a zerk fitting in the one used on the car but not yet on the spare.
