Re: heres my 1980 regal limited w/ new updates
ok so my build has gone so far off budget and time limit its not funny. so i have some updates to make but ill have pictures sometime or another.
Engine:
Ok so i broke the motor down and the block is at the machine shop being honed, decked. All my motor parts came in today. she will be going back together soon enough.
Parts list:
Profiler 195 cc 64cc alluminum heads with port work by chad speier
Edelbrock performer rpm intake with gasket matched to 1206 and ported by chad speier
KB +.060" #231 pistons 2valve relief 6cc
Scat forged 5.7 rods
Howards retro roller cam PN: 110265-12 (.533 .548 234/242@ 50)
cloyes billet roller timing set with torrington bearing
Cloyes 2 piece from cover
Ignition:
MSD Digital E Curve
MSD 6A Box
MSD Blaster SS coil
MSD Super conductor 8.5mm wires
Fuel System:
Planning on getting the F.A.S.T. EZ EFI setup with a
grand national fuel tank w/ in tank pump (Still need)
Rear End:
8.5 out of an 87 grand national w/ 3.42 gears
moser 28 spline hardened axles
moser girdle rear cover
S10 wheel cylinders for rear brakes
Transmission:
TH350 w/ 36 element sprag, Auto/manual valve body, deep aluminum cast pan, red frictions
Hughes 3,000 Stall
Suspension:
C3 Fab rear tubular upper control arms
HR Parts N Stuff Rear lower control arms w/ rear sway bar
UMI rear control arm braces (connects upper and lower control arm mounts)
Hotchkis lower springs on all 4 corners
energy bump stops and sway bar links
fender to core support braces
GP bar
Jounce Bars
radiator support x braces
making a custom front and rear frame horn braces
bilstien hd shocks on all 4 corners
jeep steering shaft
Body:
picked up all trim that i was missing
picked up an excellent condition front bumper.
need fillers and paint.
extras:
Line lock
no real picture updates so to speak of but i will throw these out there. i completley stripped the 8.5 down to bare metal. prepped with ospho. then primed with rustolium primer and painted with rustolium gloss black (brushed on)
