It's been 2 Howe and a RAM currentlyWhich brands did you use?
I wanna be like you when I grow up. 😎I had a Howe that blew which cost me a new clutch, used a slave and fork after that and now I have a McLeod that is working great.......so far....
The 3.75 first ratio is steep but these are the strongest, 310 ft/lbs rated and easiest to find. I like that the dual pattern BOP bell housing, came specifically behind the Olds V8, thanks to the Ford top loader option, allows it to bolt right on the F body V6 trans. Make sure the input length is right, it may need trimming.
