Mechanical or Hydraulic? (vote)
Mechanical clutch or Hydraulic clutch?
  • Total voters
    36
307 Regal
1,667
914
Northern Indiana
I have an older bellhousing so my T5 sits straight. I removed the fulcrum from the hurst shifter, heated it up and removed the 17° angle. I like the McLeod TOB better then the Howe cause the Howe has a limit of maximum 3/4" pedal travel with a 3/4" master. more that the limit over extends the piston on the Howe and the piston can pop out. The McLeod on the other hand has a minimum limit of 1" pedal travel and mentions no maximum travel so it is easier to set the stop for the clutch pedal.
What did you do for the 18 degree transmission mount?
pontiacgp
blank
Mar 31, 2006
29,276
20,370
Kitchener, Ontario
I moved the pad over on the iceman support and made an angled shim out of aluminum. I'm trying to find a Nissan T5 tailhouse since that transmission sits straight and the tailhouse looks like it may work
  • Winner
307 Regal
1,667
914
Northern Indiana
I moved the pad over on the iceman support and made an angled shim out of aluminum. I'm trying to find a Nissan T5 tailhouse since that transmission sits straight and the tailshaft looks like it may work
Is that out of a 300ZX?
Also, so you put the 18 degree wedge on the tail and your rubber mount sits straight up? How’s your ground clearance?
pontiacgp
blank
Mar 31, 2006
29,276
20,370
Kitchener, Ontario
I am not sure what Nissan that transmission is out of, I came across it when searching for a tailstock. The poly mount sits on the crossmember and the shim is between the mount and transmission. Ground clearance is fine as the transmission sits above the crossmember and the engine is sitting at a good angle
Just came across this....Borg-Warner T-5 in 1982-1983 280ZX Turbo
pontiac guy
583
845
Royse City, TX
What is that weird bellhousing?
You are really far back with the tail housing and shifter. Where will it come up?
307 Regal
1,667
914
Northern Indiana
Nissan T5. I read that some of the Z cars used them.
black_aerocoupe
106
46
I can’t decide! I’m doing a manual transmission swap and I can’t decide between a hydraulic throw out or a factory type mechanical setup. I would prefer to do an external slave cylinder style but that seems like it will take some skilled fabrication out of good metal. This is a Buick V8, a Firebird bellhousing, and a Camaro V6 T5. Is a mechanical setup really that hard on your leg? Are internal hydraulics really that prone to failure? What’s your experience?
I ran 84-92 Camaro V8 T5, master / slave and bell. The shifter position is really good for a G-body console. The 200-4R speedo cable worked with it. The hydraulics worked like in a Camaro. It required crossmember mods, a hole in the floor, and pedals welded to work. Everything else was "buy replacement parts for a Camaro." This was a nice setup because I had a stock style clutch, the V8 ratio T5 which matched the 305 / 3.73 rear very well (your V6 setup is one I've passed by many times on purpose.) For used parts, I was very happy with this setup and I drove it over 1000 miles one way shortly after the swap.
My next setup was mechanical speed direct rod-end linkage, the 83 camaro bellhousing, and another V8 Camaro T5. Basically nothing was "better" except the trans. was WC and I had rebuilt it but it all worked correctly. The 83 camaro has no benefit over the 84 Camaro. Would I rather unbolt and replace hydraulics, or get the z-bar and linkage re-welded? I'd go hydro.
I later modded a 94-97 T56 to take a T56 throwout bearing and clutch in the 93-97 bellhousing. Worked fine. But no real benefit over the hydraulic. In retrospect, the 94 Camaro ratios weren't a good match like the V8 T5 ratios.
I think that sounds right. TKO 500 and 600 only differ in their gear ratios. Less multiplication of torque means more capacity they say.
Any time a pair of gears are farther apart in size, they are weaker in design. A small pinion in a 4.56 gearset is automatically weaker than a larger pinion in a 2.73 gearset. This same concept applies to the V6 ratios vs. the V8 ratios. The main issue though, is the gear ratios putting the engine in a happy power range, and percentage of rpm drop off with shifts.
I'll leave the V6 ratios deadhorse alone now. :)
  • Informative
MrSony
6,642
6,316
Des Moines, Iowa
Don't forget Buick 350s are very torquey down low.
csstrux
143
76
Guys have used the 84-88 Corvette bell housing which seems to be easier to find. I can't answer whether you need the 78-81 A body specific fork as I have never used anything but the 78-81 stuff.
The problem with using a standard bell housing and fork is the end of the fork makes contact with the floor pan in the corner under the gas pedal.
IDK if it corrulates, but I put an SBC/ T5 compo into a 3rd gen Supra using the factory slave/master from the car. They use an external slave that was fairly easy to fabricate a bracket to attach to tha bellhousing. I cut a factory 2nd gen F body fork down to clear the tunnel. Pedal was light and worked like a champ. IDK what it would take to mate with a GM master, or get the Nippon master correctly into the G body chassis, but it was a functional compact hybrid that worked for me. Seems to me that if you can make what you have work, you got a winner.
