Mega shifter
Fishbait17
41
14
New here, I was woundering if anybody had any tips on installing a megashifter into my 79 elky. It was originally a bench seat column shift if now converting to a
Bucket and a floor shift.
19,992
second tip place it in this
500/600
1,167
2,638
West Virginia
Mine was originally console mounted. Not any more. You’ll need to do some accurate measuring to get the fore/aft and height correct. See if B&M has model specific instructions to download.
Fishbait17
41
14
First tip: don't throw the backdrive linkage out. It controls your ignition lock and reverse lights.
I know that the shifter comes with these little switch for the reverse light and neutral safety switch u think I could just wire those to the shifter.
12,176
9,795
[/QUOTE .
You could do it that way, but frankly it's easier to use the shifter/ linkage/ backdrive. When I used an aftermarket shifter, I made a wiring harness connected to the the two micro switches for neutral safety switch and backup lights. It required cutting and splicing into the two circuits. I don't like doing it that way.
I also locked the column collar in the park position.
This was a Hurst V-matic shifter. I'm sure they connect the same way.
Fishbait17
41
14
Ok I see, so any ideas of how I would set up the shifter with stock backdrive?
mikester
2,928
3,721
Small town NY
Jack, after pulling whats left of my hair out with that stupid shifter I wound up buying a relay for the neutral safety. Do you remember how you wired it ? I thought I had the right plug but it wouldnt stop the car from turning over no matter how I ran the two wires.
