on those wedge mirrors... they were used on El Caminos, MCSS, Fiero, Camaro, and Corvette. in every single case, even the stalk that sits on top of the gasket is different due to the door shape, and so is the gasket that it mounts to.Just gonna guess here since you give no information as to which mirrors you have. I'll assume you mean sport mirror gaskets.
You need 2 of p/n 20009400. Or equivalent. GM made about 3,200 (exaggerating to clarify) different mirror configurations for the A/G-body over the years that required their own door to mirror gaskets. So I cannot reliably determine whether any other mirror gasket would work in its place. Some bases were bigger than others. I see MANY aftermarket companies who don't know squat say that their junk fits all 78-88 but that may or may not be true. I don't know for sure. I can't keep up with the junk I got, let alone try to be an expert on Chevy A/G-body mirror gaskets. Hopefully someone with your same issue has an alternative fix. If you happen to find a 80-82 X-body (like a Citation) with sport mirrors in the j/y, it's got the same gasket. I do know for a fact later Cutlass/Regal sport mirror gaskets will not work as the holes are way off center, nor will the Chevy wedge mirror ones, obviously.
81-86 Monte with sport mirrors uses 20157825. Not sure if it's the same size but if so, it MAY work. I don't know. At least you can get repros of those.
From what I can gather, even the ElCa/Cab mirrors use a different p/n gasket for their sport mirrors regardless of year.
Here's what a 1978-1980 20009400 gasket looks like.
