Yes, you'll have to hardwire it, probably. The earlier cars didn't have the 2 pin connector for the clock, so it may not have come with your harness. Even if it did, there wouldn't be anything on the car side to plug it into.
So I would hard wire acc. Power to the blue wire and it would in turn power up the grey wire . Which tells me there’s not power coming from the grey wire it needs power going to it ?Yes, you'll have to hardwire it, probably. The earlier cars didn't have the 2 pin connector for the clock, so it may not have come with your harness. Even if it did, there wouldn't be anything on the car side to plug it into.
Ok Turna I think I gotcha now .I tend to overthink things ! The crutch field tech told me to just hook blue to blue which would mean the blue antenna wire from the aftermarket radio would be going to the grey wire in my original radio harness .some simple tests when I get home from work will verify . ThanksPump ya brakes; before things get too confusing, understand this: the aftermarket plug(s) are all the same colors, and they match up wire for wire. Gray (& black stripe) are right rear speaker. Blue is for power antenna (should match to pink on the car side). Orange w/ white stripe is for dimmer and should match up to gray on the car side, but isn't necessary. The yellow on the radio side may not match to anything on the car side because the factory clock was in the gauge cluster, not the radio. On later models, there is a separate plug with an orange and a brown for the clock power. You're hardwiring the constant/memory wire (yellow aftermarket to orange factory).
Aftermarket accessory is red, and matches to yellow on the car side.
Now, That I think about it, your blue aftermarket MAY hook to gray. The antenna power wires at the antenna are gray, white, and black; they switched to pink in the later years. Blue new to gray old might be right.Ok Turna I think I gotcha now .I tend to overthink things ! The crutch field tech told me to just hook blue to blue which would mean the blue antenna wire from the aftermarket radio would be going to the grey wire in my original radio harness .some simple tests when I get home from work will verify . Thanks
You’re right funny thing is the dome light is on but the lighter is blown . And after some research I see that grey wire in the old harness is the headlight dimmer wire . Why in hell would the headlight dimmer wire go through the radio ??No problem. The lighter and dome/courtesy are the same circuit. They can be a bear to troubleshoot.
found this posted on this siteYou’re right funny thing is the dome light is on but the lighter is blown . And after some research I see that grey wire in the old harness is the headlight dimmer wire . Why in hell would the headlight dimmer wire go through the radio ??
