Most Common G-Body Problems
Rear “clip” in wheel cylinders. Why on earth did they do that - when a standardized backing plate with bolt in cylinder had been on the shelf - for what ? Fifteen years?? Guess the bolt in style can be swapped over
The almighty dollar my friend. They could save a couple of cents per car by going with a lighter/simpler/cheaper method thereby increasing profits. Department inter communication at GM was still in its infancy and part sharing was still taboo.
Get used to it, you’re gonna find things like that quite a bit on our cars.
If you ever pull your body to do a frame off resto, frame paint, cage install or whatever, then hold onto your hat for some of the worst splattered welds you'll ever see. Whatever you do, don't run your bare hand over the frame quickly in factory welded areas unless you appreciate the sight of your own blood.
And yes, to save the almighty dollar as described by Donovan.
Lets face it. No older car was ever meant to be restored, let alone taken apart to be restored. They were used, parked when it was the end and then junked.
I've read this thread and its all of the above. I've owned 79 Hurst Olds - 1 Clone of it - 88 Cutlass Supreme Classic - 86 442 and now a 80 442.
In the south they don't rot out unless it was a T-Top car and those sucked anyway and leaked and then the floor rotted.
I think it is all of everything. Thank goodness a Cutlass, Regal, Monte Carlo has many pieces that interchange unless someone's doing a OEM
Slow-a$$ windshield wipers. The "high" setting is painfully slow, the "low" switch is even worse. Cleaned the motor, trans, and contacts at the switch, but still S-L-O-W
Try an electric washer pump the old wiper motor driven ones really slow down the wiper motors when they are worn.
With the electric pump I think the hi setting is too fast.
Check your grounds as well.
