Make sure there is a bulb in the 'volts' idiot light. I'm pretty sure that turns the regulator on in the alternator. Verify 14.4v above idle.
Now there's something I didn't even consider. I'll fiddle with some wiring and see if I can get it to chooch. I don't wanna put a new bulb in my dash, but I do have an extra one so I might as well if it's needed to make it work. Shouldn't take me very long.
I hope it works with an LED bulb, because that's what I've got hahaThe light is required to complete the circuit and gives the circuit the resistance that is required. The system with gauges has a resistor in the wire to simulate the light. If the light is burnt then the alternator does no get excited and will no charge.
So basically I can get an inline resistor, connect the "idiot light" wire to one side, and the other side to ground, and it'll fool the regulator into working? How much resistance would it need?nope, it will not work with an LED. You can use a switched wire to tap in a wire with a resitor that you connec to the brown wire at the plug for the alternator. The reason for the light in the dash is that when you start the car the light goes on to show you the circuit is on and is functioning properly if the light goes out. Bypassing that you won't actually know if it working or not, with a guage you no longer need the light if you wire in a resistor. I have aftermarket guages so I have the resistor in the brown wire that goes to a switched circuit.
Or maybe I can use an inline resistor in conjunction with an LED so it'll work and I'll know it's doing it's thing.So basically I can get an inline resistor, connect the "idiot light" wire to one side, and the other side to ground, and it'll fool the regulator into working? How much resistance would it need?
