For now though, the car is going to sit outside for a bit while I clean up the garage and work on some other things I should have fixed already on other cars.
I'll try that. It was working fine before I changed over to the new tank though too so it's even more of a head scratcher. I hope the new tank isn't having a problem with the float, because that'll be very difficult to fix.for the gas gauge issue I had a bad wire in the harness that goes from the left side of the fuse box to the connection in the trunk. To check it I strung a wire from the wire coming from the sender and shoved the other end into the pink wire connection on the left side of the fuse box.
