motor keeps killin on me
check the connections for the vac hoses on the carb. grab u a can of brake clean and spray on the manifold and around carb while engine is running to help find your vac leak. you will notice a change in idle when the engine sucks up brake clean from the leaking area.
i think i got some carb cleaner i can use i didnt think of that....a guy told me dump a mixture of windex and soap on the manifold i didnt see how it would help
dont know how it would help but im sure u would hear a difference in idle once the engine sucks it in from the leaking area. ive always used brake clean, or carb cleaner either will work.
ok cool ima try in the morning and ill let yall know unless it rains
no vac leak but unhooked vac line to egr and is runnin fine
well with egr capped off the prob is back so im not sure what to do...i was going 60mph let off the gas to slow down and it killed but i could stomp the gas and it would fire back up but the second i left off die again.....idk it was at first jus comin to stops but now its very often jus anytime at random
Ok, sounds like a fuel pump going bad, or fouled plugs can do that also...also do you have a lock up transmission? if so the lock up may not be disengaging
but its a new pump and plugs but the trans deal idk
try leaving the vac line open, the motor should idle at a higher rpm if this seem to fix the problem then you may need to adjust your idle on the carb
